QUI le specifiche
Bike InformationWheel................................................ size 16" (349mm)
Folded dimensions............................... 585mm high x 565mm long x 270mm wide (23" x 22.2" x 10.6").
Handlebar........................................... type M type (1015mm)
Rear frame.......................................... L type (mudguard)
Colours............................................... Gloss black or Gloss white
Gears................................................. 2-speed or 6-speed
Seat posts .......................................... Standard - adequate for an inside leg measurement up to 33"
.......................................................... Extended - 60mm / 2.5" longer than the standard option
.......................................................... Telescopic - designed for an inside leg greater than 35"
Weight: bike without battery.................. 2-speed: 13.7kg (16.6kg total with battery)
.......................................................... 6-speed: 14.4kg (17.3kg total with battery)
Weight: battery & small bag................... 2.9kg
Lights................................................... 20 Lux Busch & Müller LYT
Max. load............................................. 107kg (incl. luggage)
Brakes................................................. Dual pivot brakes
Luggage Small bag (included)................................... 1.5 litres
Large bag (optional accessory)..................... 20 litres - additional £130
Charger Standard charger (included)........................ 2A charger (80% charge in 3-3.5 hours, 100% in 4-5 hours)
Fast charger (optional accessory)..................4A charger (80% charge in 1.5-2 hours, 100% in 2.5-3 hours) - additional £115
Battery Voltage..................................................... 36V
Capacity.................................................... 8.55Ah
Energy density........................................... 300Wh
Range....................................................... 25-50 miles / 40-80km (dependent on rider and environmental factors)
USB port to charge portable devices............... 5V 1.5A
Integrated HMI........................................... LED display
Weight...................................................... 2.2kg
Assistance Assistance modes......................................... 4 (0-1-2-3)
Sensors....................................................... Contactless bottom bracket torque and cadence sensor
Motor Type Brushless DC front motor
Nominal output power.................................... 250W
Cut off speed................................................ 15.5mph / 25kmh
Freewheel..................................................... Very low resistance when riding without assistance
Warranty on electrical parts............................. 2 years
Certifications.................................................. EN15194
Battery:......................................................... UN38.3, EN62133
App............................................................... iPhone app
