Autore Topic: Luci ad induzione: Magnic Microlights  (Letto 66764 volte)
  • Post: 3441
Re:Luci ad induzione: Magnic Microlights
« Risposta #60 il: Gennaio 17, 2022, 03:39:43 pm »
meglio accorgersene tardi che mai....
  • Post: 3441
« Risposta #61 il: Febbraio 14, 2022, 06:23:47 pm »
aggiornamento 49/50 Inglese e tedesco, come al solito)
https://www.kickstarter.com/projects/dynamodirk/magnic-microlights-bikelights-with-magic-non-conta/posts/3420579
Mass production
Dear Backers,
On Monday we received new production material for the Wega & Microlight lamps. However, we have hardly made any progress with the deliveries since December, since problems in production were noticed after the first deliveries, which have only now slowly been resolved. Manual work was sometimes too time-consuming, so I built new tools that make assembly faster and more precise.
New rear light lenses
I was relieved that the new rear light lenses which I anounced in December (including the new design and sample test) could be developed within the expected time frame. (See STVZO update in December: previous version was too focused for future STVZO requirements). Now the new lens design has wider  STVZO-compliant light distribution and  6,000 have already been produced and are ready for installation.
The new optics creates a ring structure with good visibility, even when the stand light brightness decreases after a few minutes.
These new lenses still have to be tested for approval in Germany, which we have been waiting for for a few weeks now.
Wega generator arms
With the Wega lamps delivered to date, the lower ball joint element must be tightened very firmly so that the generator does not fold away when using the longer arm (required for high-profile rims and Vbrake/Magura systems).
This ball joint connection has now been significantly improved by applying a carbon assembly paste with microparticles: It withstands extreme impacts even with medium-tight screw connections. We will send this paste to the supporters who have already received Wega lamps for retrofitting.
This video from our assembly tutorial collection shows the assembly of these arms using 3D printed tools including application of the red carbon assembly paste - still a lot of manual work but much faster than the earlier assembly without tools.
Tools for production
There were further problems with clean casting of the cables for the generator and headlight housing. For this we have now printed a larger quantity of magnetic holder shapes for easier processing.
Other tools make it easier to put on the sealing rings for the housing and lenses.
These O-rings are lubricated with silicone grease for optimum watertightness. This was difficult in the previous workflow (due to grease on the fingers during assembly) and now works cleanly and much faster with special 3D printed grease nozzles:
Microlights
All production molds for the Microlights have been ready for months now, but I have could not give approval for mass production because the shifting mechanism between the generator and aluminum brake shoe did not work as desired: This mechanism ensures that the generator automatically slides away from the rim when the brake rubber becomes thinner over time and so prevents damage. The cause is a slight deformation of the generator housing (when it cools down in the injection molding process), which has already been revised several times last year. The new samples which arrived here on Monday have no deformation and the next step is to check whether everything will remain in order even with the production of a medium number of items. However, production at our producer's will only continue in two weeks, so that we can at best send the first microlights at the end of February.
Shipping
An online database for update & confirmation of address data and rewards is ready for some weeks now. This should be activated with confirmation of the mass production of the Microlights, since only then can a relatively reliable delivery date be predicted. I hope that this will work within the next three weeks.
All Wega lamps can be  produced in February - but currently only a few hundred can be finished completely, since two small parts were delivered in far too small quantities:
We need two of the two smallest parts per lamp for the ball joints of the Wega generator mount and only have a few hundred in stock. We had expected these items with the current delivery on Monday and now have to wait for the next delivery mid-February.
We hope for your understanding.
Thank you very much for your support!
Dirk from Magic Light
traduzione di Google (dal tedesco)
2 febbraio 2022
Cari sostenitori,
All'inizio di questa settimana abbiamo ricevuto nuovo materiale di produzione per le lampade Wega & Microlight. Tuttavia, da dicembre non abbiamo fatto quasi nessun progresso con le consegne, poiché si sono notati problemi di produzione e consegna dopo le prime consegne, che solo ora sono stati risolti lentamente. Il lavoro manuale a volte richiedeva troppo tempo, quindi ho costruito nuovi strumenti che rendono l'assemblaggio più veloce e preciso.
È stato gratificante che la modifica alle lenti del fanale posteriore annunciata con breve preavviso a dicembre (incluso il nuovo design e il test di esempio) abbia funzionato entro i tempi previsti. (Vedi aggiornamento di dicembre: a causa dell'eccessiva luminosità in alcune aree, gli obiettivi erano troppo luminosi per i test che verranno applicati in futuro e sono già utilizzati nel contesto dell'attuale STVZO). Nel frattempo, non solo i nuovi modelli con distribuzione più ampia conformi a STVZO sono già pronti, ma ne sono già stati prodotti 6.000 e sono pronti per l'installazione.
La nuova ottica crea una struttura ad anello molto facile da vedere, anche quando la luminosità delle luci di posizione diminuisce.
Queste lenti devono ancora essere controllate per l'approvazione in Germania, cosa che stiamo aspettando da alcune settimane,
Porta generatore Wega
Con le lampade Wega che sono state spedite fino ad oggi, lo snodo sferico inferiore doveva essere serrato molto saldamente in modo che non vi fosse il rischio che il generatore si ripiegasse quando si utilizzava il braccio di leva più lungo (necessario per cerchi ad alto profilo e sistemi Vbrake/Magura ).
Questa staffa è stata ora notevolmente migliorata applicando una pasta di assemblaggio in carbonio con microparticelle e resiste a impatti estremi anche con collegamenti a vite di media tenuta. Invieremo questa pasta ai sostenitori che hanno già ricevuto le lampade Wega per il retrofit.
Questo video della nostra raccolta di tutorial sull'assemblaggio mostra l'assemblaggio di questi bracci di sostegno utilizzando strumenti stampati in 3D, inclusa l'applicazione della pasta speciale rossa: ancora molto lavoro manuale ma molto più veloce rispetto al precedente assemblaggio senza strumenti.
Strumenti per la produzione
Ci sono stati ulteriori problemi con l'invasatura pulita dei cavi per il generatore e l'alloggiamento del faro. Per questo abbiamo ora stampato una quantità maggiore di moduli di tenuta magnetici per una più facile elaborazione.
Altri strumenti facilitano il montaggio degli anelli di tenuta per l'alloggiamento e le lenti.
Questi O-ring sono lubrificati con grasso al silicone per una tenuta stagna ottimale. Questo era difficile nel flusso di lavoro precedente (a causa del grasso sulle dita durante il montaggio) e ora funziona in modo pulito e molto più veloce con speciali ugelli per grasso stampati in 3D:
Microlights
Tutti i moduli di produzione per le Microlight sono pronti ormai da mesi, ma non ho ancora potuto dare l'approvazione per la produzione in serie perché il meccanismo di collegamento tra il generatore e la ganascia del freno in alluminio non funzionava come desiderato: questo assicura che il generatore scorra automaticamente col tempo man mano che la gomma del freno si assottiglia viene spinta verso l'esterno e non sfrega contro il cerchio. La causa è una leggera deformazione dell'alloggiamento del generatore (quando si raffredda durante il processo di stampaggio ad iniezione), già revisionato più volte nell'ultimo anno. Lunedì abbiamo finalmente ricevuto gli ultimi campioni senza alcuna deformazione e il passo successivo è verificare se tutto rimarrà in ordine anche con la produzione di un numero medio di articoli. Tuttavia, la produzione presso il nostro produttore continuerà solo tra due settimane, in modo da poter inviare al massimo i primi esemplari delle Microlights alla fine di febbraio.
Spedizione
Un database online per l'adeguamento dei dati dell'indirizzo e per la modifica e l'aggiunta ai premi è stato approntato alcune settimane fa. Questo dovrebbe essere attivato con la conferma della produzione in serie dei Microlight, poiché solo allora è possibile prevedere una data di consegna relativamente affidabile. Spero che questo funzionerà entro le prossime tre settimane.
Tutte le lampade Wega possono essere completate a febbraio, ma attualmente solo poche centinaia completate, poiché purtroppo due piccole parti sono state consegnate in quantità troppo piccole:
Abbiamo bisogno di due delle due parti più piccole per i giunti sferici del supporto del generatore Wega per lampada e ne abbiamo solo poche centinaia in stock. Ci aspettavamo questo con l'attuale consegna di lunedì e ora dobbiamo aspettare la prossima consegna a metà febbraio.
Speriamo nella vostra comprensione.
Grazie per il vostro sostegno!
Dirk di Magic Light
aggiornamento 51 del 12 febbraio
STVZO rearlight check successful
Dear Backers,
Yesterday we received the news that the rearlight check for the new rearlight lenses for German STVZO approval was successful.  (The front light check was successful before but the first version of the rearlight lenses was too much focused and too bright for approval- see my recent updates).
After many unsuccessful attempts in the recent years, this is an important milestone for our project.
I will post more news on delivery soon.
Dirk from Magnic Light
Controllo del fanale posteriore STVZO riuscito
Cari sostenitori,
Ieri abbiamo ricevuto la notizia che il controllo del fanale posteriore per le nuove lenti del fanale posteriore per l'approvazione tedesca STVZO ha avuto successo. (Il controllo della luce anteriore ha avuto successo in precedenza, ma la prima versione delle lenti della luce posteriore era troppo focalizzata e troppo luminosa per l'approvazione, vedere i miei recenti aggiornamenti).
Dopo molti tentativi falliti negli ultimi anni, questa è una pietra miliare importante per il nostro progetto.
A breve posterò altre notizie sulla consegna.
Dirk di Magic Light
« Ultima modifica: Febbraio 14, 2022, 06:27:58 pm by Vittorio »
  • Post: 3441
« Risposta #62 il: Marzo 16, 2022, 10:34:53 pm »
Aggiornamento 52 del 15 marzo 2022
https://www.kickstarter.com/projects/dynamodirk/magnic-microlights-bikelights-with-magic-non-conta/posts/3455263?ref=ksr_email_backer_project_update_unregistered_users
Dear Backers,
A few weeks ago it was planned to ship all pre-ordered Wega lights by the end of February and to be able to start assembling the microlights with the revised aluminum housings. It is now mid-March and we have not achieved either goal.
After all, in tests on "exotics", such as this folding bike with 20 inch wheels, we were able to determine that the Wega lights can also be installed here without any problems and work excellently:
(Folding bike with Wega lights)
The pre-ordered Wega lamps are now "practically" ready, but the missing small parts for the ball joints, which are used to align the generator on the rim (see my last update), are still missing in full number. After these parts were inadvertently only included in small quantities in the previous delivery, they are now in stock -but although they have been ready for dispatch from our partner in Shenzhen for a few days, they cannot be dispatched this week either.
In the last few weeks we have received pictures like this from Shenzhen, which shows a long queue for the daily corona tests and explains why regular work was hardly possible there in February:
Yesterday I got the news that a complete lockdown has been imposed for this week and we hae to hope for next week. Anyone who, in view of the terrible news in Europe, has not noticed the almost forgotten Corona news from China can read them here, for example: https://www.independent.co.uk/asia/china/china-shenzhen-lockdown-covid-cases- b2035242.html
Alternatively, I could reproduce the missing small parts with our own 3D printers, but this would take some time, too and would mean less stability and UV/heat resistance. We create most of the assembly tools and complete winding machines from the plastic PLA with our 3D printers. However, in high summer temperatures, these parts would soften, so we need to switch to different filament like ABS. I am now hoping that the lockdown will end next week and that  shipment will reach us quickly via air freight. In the meantime I will be doing some tests with "home-printed" parts just to be safe.
The delivery of components for the Microlights is done separately, due to the greater weight and volume involved: As with previous deliveries, the shipment was planned by rail (passing Russia and Ukraine), which now no longer seems correct. I don't know yet whether we can also do this by air freight or whether there are alternative routes and I have to wait and see what the next few days will bring.
We have few orders from Russia and the Ukraine and I hope that we will soon see times when shipping is not a problem here either. Even if it is hardly comprehensible for me here in Germany, for many people on the "other side" there is obviously an opposite picture of reality and the search for consensus seems hopeless. At least we should be able to agree on the hope that we will be spared such an extinction as the dinosaurs once experienced.
With this in mind, I hope for a better world and look forward to contributing a little to it by delivering your lamps as soon as possible.
traduzione di Google:
Cari sostenitori,
Poche settimane fa era previsto di spedire tutte le luci Wega preordinate entro la fine di febbraio e di poter iniziare ad assemblare le Microlights con gli alloggiamenti in alluminio rivisti. Ormai è metà marzo e non abbiamo raggiunto nessuno dei due obiettivi.
Del resto, nei test su [mezzi] "esotici", come questa bici pieghevole con ruote da 20 pollici, siamo riusciti a stabilire che le luci Wega possono essere installate anche qui senza problemi e funzionano egregiamente:
(Meglio tardi che mai per scoprirlo...)
(foto di bici pieghevole con ruote da 20" e luci Wega)
Le lampade Wega preordinate sono ora "praticamente" pronte, ma mancano ancora in numero completo le minuterie per gli snodi sferici che servono per allineare il generatore sul cerchio (vedi mio ultimo aggiornamento). Dopo che queste parti sono state inavvertitamente incluse solo in piccole quantità nella consegna precedente, ora sono in magazzino, ma sebbene siano state pronte per la spedizione dal nostro partner a Shenzhen per alcuni giorni, non possono essere spedite nemmeno questa settimana.
Nelle ultime settimane abbiamo ricevuto immagini da Shenzhen che mostrano una lunga coda per i test corona quotidiani e spiegano perché a febbraio non era possibile lavorare regolarmente lì:
(D'accordo che un ritardo nella spedizione non è certo fra i principali danni della pandemia, ma ci mancava anche questa...)
Ieri ho ricevuto la notizia che per questa settimana è stato imposto un lockdown completo e dobbiamo sperare per la prossima settimana. Chiunque, vista la terribile notizia in Europa, non si sia accorto delle notizie quasi dimenticate di coronavirus dalla Cina può leggerle qui, ad esempio: https://www.independent.co.uk/asia/china/china-shenzhen- lockdown-casi-covid- b2035242.html
In alternativa, potrei riprodurre le piccole parti mancanti con le nostre stampanti 3D, ma anche questo richiederebbe del tempo e significherebbe meno stabilità e resistenza ai raggi UV e al calore. Creiamo la maggior parte degli strumenti di assemblaggio e avvolgitori completi dal PLA plastico con le nostre stampanti 3D. Tuttavia, nelle alte temperature estive, queste parti si ammorbidirebbero, quindi dobbiamo passare a un filamento diverso come l'ABS. Ora spero che il blocco finisca la prossima settimana e che la spedizione ci raggiunga rapidamente tramite il trasporto aereo. Nel frattempo farò alcune prove con parti "stampate in casa" solo per sicurezza.
(Dirk, dai retta a un cretino: non ti andare a impelagare in un'altra serie di prove e controprove che alla fine ci perdi più tempo che ad aspettare che arrivi 'sto cavolo di pacco)
La consegna dei componenti per le Microlight viene effettuata separatamente, a causa del maggior peso e volume coinvolti: come per le consegne precedenti, la spedizione era pianificata su rotaia (passando per Russia e Ucraina), che ora non sembra più corretta.
(Eh, no, oggi come oggi la "Via della seta" ferroviaria non sembra una buona idea)
Non so ancora se possiamo farlo anche con il trasporto aereo di merci o se ci sono rotte alternative e devo aspettare e vedere cosa porteranno i prossimi giorni.
(Come tutti noi...)
Abbiamo pochi ordini dalla Russia e dall'Ucraina e spero che presto vedremo tempi in cui la spedizione non sarà un problema neanche qui.
(Anche in questo caso, immagino che russi e soprattutto ucraini abbiano problemi più gravi del ritardo di consegna delle Microlight)
Anche se per me è difficilmente comprensibile qui in Germania, per molte persone dall'"altra parte" c'è ovviamente un'immagine opposta della realtà e la ricerca del consenso sembra senza speranza. Almeno dovremmo essere in grado di essere d'accordo sulla speranza che ci sarà risparmiata un'estinzione come quella vissuta un tempo dai dinosauri.
Con questo in mente, spero in un mondo migliore e non vedo l'ora di contribuire un po' ad esso consegnando le vostre lampade il prima possibile.
(Lo speriamo tutti, mein Freund...)
« Risposta #63 il: Marzo 17, 2022, 03:30:30 pm »
in attesa che gli alieni ed un asteroide si uniscano a completare il quadro puoi ascoltare  QUESTA CANZONE  ;) :D
  • Post: 3441
« Risposta #64 il: Marzo 17, 2022, 05:47:11 pm »
Come direbbe Coliandro: "comincio ad avvertire una leggerissima puzza di presa per il ...."  ;) ;)
  • Post: 3441
« Risposta #65 il: Giugno 25, 2022, 07:03:04 pm »
Era da parecchio tempo che il buon Dirk non si faceva vivo, ma finalmente eccolo:
Aggiornamento #53
https://www.kickstarter.com/projects/dynamodirk/magnic-microlights-bikelights-with-magic-non-conta/posts/3540214?ref=ksr_email_backer_project_update_unregistered_users
Mass production of aluminum brake shoes & light comparison
Dirk Strothmann
23 giugno 2022
Dear Backers,
We have some news for you:
Microlights
Finally the mass production of the aluminum brake shoes for the microlights is complete (die casting + cnc drilling) so I'm looking forward to the black anodizing (just to get them with black color) and shipping.
(video)
Our supplier was unable to work on the Microlight brake shoes for some time after making a repair on the moulds at hot conditions (directly at the aluminum die casting facility).  This situation was also critical for our project, but fortunately he has now recovered and can organize the shipping. Now we expect the arrival here before mid-July and want to start first microlight assemblies and shipments a few days later.
Wega
We have already shipped several Wega lights, but we still have to learn from shipping problems (address details, customs declarations, mix-up of the lights orientation,...) in order to avoid major problems with bulk shipments, which will follow as soon as possible (still in June and July).  When we started this campaign we only offered Wega sets with one front light and one rear light (only for the left side). Due to a lot of requests we now offer both sided versions which also means that you can choose between left/ right and both-sided version now. Most backers like to have one rear light on the left side (in countries with right-hand traffic) and it is clear that two front lights are much more powerful than just one.  Below is the comparison between the Wega right-hand lamp and the double-sided version. In response to popular demand, we offer to update a (one-sided) Wega set by two Wega front lights. This will be possible via the online form, which I had already announced more than once and which in the meantime had to be updated several times before launch.
(Comparison between one- and double-sided Wega front lights at ~20 km/h with identical camera settings)
Microlights+Wega
Here you have the final look of the lights:
(foto)
I hope that no further problems arise and that I can start querying the addresses and rewards in the next few days.
Eurobike
We were recently asked by the Eurobike fair to participate in this year's Eurobike Innovation Award. Even if we now have a huge delay with the delivery of the products, maybe some of you still like to support our project with their voting, so that we can present the lamps as an innovation at the Eurobike in July. We would be happy. Here is the link to the Eurobike Online Voting (which ends tomorrow) where you also find some other cool bicycle innovations in different categories:
DE: https://www.eurobike.com/de/programm-highlights/events/innovators-prize/online-abstimmung/
EN: https://www.eurobike.com/en/program-highlights/events/innovators-prize/public-voting/
Direct link to our category: Accessoires
Produzione in serie di ganasce freno in alluminio e confronto luci
Cari sostenitori,
Abbiamo alcune novità per voi:
Microlights
Finalmente la produzione in serie delle ganasce freno in alluminio per le Microlights è completa (pressofusione + foratura CNC) quindi non vedo l'ora che arrivi l'anodizzazione nera (solo per averle di colore nero) e la spedizione.
(video dei pezzi in varie fasi di lavorazione)
Il nostro fornitore non è stato in grado di lavorare sulle ganasce dei freni Microlights per un po' di tempo dopo aver effettuato una riparazione sugli stampi a caldo (direttamente presso l'impianto di pressofusione dell'alluminio). Questa situazione è stata critica anche per il nostro progetto, ma fortunatamente ora si è ripreso e può organizzare la spedizione. Ora prevediamo l'arrivo qui prima di metà luglio e vogliamo iniziare i primi assemblaggi e spedizioni di Microlights pochi giorni dopo.
[certo, spedire in agosto è l’ideale...]
Wega
Abbiamo già spedito diverse luci Wega, ma dobbiamo ancora imparare dai problemi di spedizione (dettagli dell'indirizzo, dichiarazioni doganali, confusione nell'orientamento delle luci...)
[si capisce, non avendo avuto tempo di prepararsi…]
per evitare grossi problemi con le spedizioni all'ingrosso, che seguiranno come il prima possibile (sempre a giugno e luglio). Quando abbiamo iniziato questa campagna abbiamo offerto solo set Wega con una luce anteriore e una luce posteriore (solo per il lato sinistro). A causa di molte richieste, ora offriamo versioni su entrambi i lati, il che significa anche che ora puoi scegliere tra la versione sinistra/destra e su entrambi i lati. Alla maggior parte dei sostenitori piace avere una luce posteriore sul lato sinistro (nei paesi con circolazione a destra) ed è chiaro che due luci anteriori sono molto più potenti di una sola. Di seguito il confronto tra la lampada Wega destra e la versione bifacciale. In risposta alla grande richiesta, offriamo l'aggiornamento di un set Wega (unilaterale) con due luci anteriori Wega. Questo sarà possibile tramite il modulo online, che avevo già annunciato più di una volta e che nel frattempo doveva essere aggiornato più volte prima del lancio.
(Confronto tra luci anteriori Wega singola e doppia a ~20 km/h con impostazioni della fotocamera identiche)
Microlights+Wega
Ecco l'aspetto finale delle luci:
(foto dei pezzi definitivi)
Spero che non sorgano ulteriori problemi e di poter iniziare a interrogare gli indirizzi e le ricompense nei prossimi giorni.
[la speranza dei nudi, che faccia un inverno caldo...]
Eurobike
Di recente la fiera Eurobike ci ha chiesto di partecipare all'Eurobike Innovation Award di quest'anno. Anche se ora abbiamo un enorme ritardo con la consegna dei prodotti, forse alcuni di voi amano ancora sostenere il nostro progetto con le loro votazioni, in modo da poter presentare le lampade come innovazione all'Eurobike di luglio. Saremmo felici. Ecco il link alla votazione online di Eurobike (che termina domani)
[il 24, quindi è già terminata]
dove trovi anche altre fantastiche novità sulle biciclette in diverse categorie:
IT: https://www.eurobike.com/en/program-highlights/events/innovators-prize/public-voting/
Link diretto alla nostra categoria: Accessori
Grazie mille per il vostro sostegno!
Dirk di Magic Light
Aggiungo un paio di commenti presenti sulla pagina di Kickstarter:
“Sfortunatamente, il tutto si sta trasformando in una farsa ... Non vedevo davvero l'ora che arrivassero le lampade, ho acquistato lampade montate a basso costo per colmare il divario e infine ho installato luci già pronte con dinamo a mozzo. Purtroppo non trovo le notizie eccitanti o interessanti dopo 3 anni. Mi dispiace infinitamente scrivere queste righe, ma quante volte è stato annunciato che verranno inviate le lampade o verrà inviato un sondaggio. Purtroppo fino ad ora non è successo nulla. Viene costantemente sviluppato e migliorato, ma sfortunatamente non viene consegnato. Certo, la pandemia e le crisi hanno lasciato il segno, ma purtroppo hanno anche eroso la credibilità. Ho avuto la prima versione delle lampade e ho pensato che fossero davvero fantastiche. Non vedevo l'ora della nuova versione, sono stato uno dei primi sostenitori, ma ho rinunciato a riceverla. O? Quando arriva il sondaggio? Le mie bici sono cambiate molto tempo fa. Quanto tempo ci vuole dopo il sondaggio per ottenere le luci? È ora di continuare ad aspettare... è un peccato...”
“3 anni e 6 mesi da quando mi sono unito a questo kickstarter. Non possiedo nemmeno più la bici.”
E adesso, pausa estiva...
  • Post: 3441
« Risposta #66 il: Settembre 05, 2022, 12:06:45 pm »
Aggiornamento #54
https://www.kickstarter.com/projects/dynamodirk/magnic-microlights-bikelights-with-magic-non-conta/posts/3596651?ref=ksr_email_backer_project_update_unregistered_users
Microlight & Wega Status
Dirk Strothmann
31 agosto 2022
Dear Backers,
In the last few days I have received many inquiries about shipments and an update on the current status.
Situation is as follows :
    • The pre-ordered Wega lights have been produced and are waiting to be shipped, while we have already shipped the first relevant quantities and learned from mistakes.
    • The first small batch of alumnium pieces (brake shoes) for the Microlights has arrived. After many immature samples the last months these new parts are finally working as intended .
Contrary to what was announced and unlike earlier samples, these parts are not yet black anodized but still have the bare aluminum surface.
[Foto 1]
New silver samples (not yet anodized) are finally working now
We can ship these raw aluminum finished parts to customers who don't care about the finish - the majority of the black anodized parts will arrive here in September and then be shipped. Our supplier's situation is still difficult (yesterday I received bad news regarding new Corona restrictions in this region), but we hope this doesn't affect the shipping too much.
[Foto 2]
 First delivery of working samples for Vbrake/Cantilever (front/left) & roadbike brake shoes
With these parts working, we are now ready to send out questionnaires (for address and reward updates) and ship your pre-ordered lights.
Nevertheless I don't start this today, but want to wait until September 9th (contrary to my earlier announcements) because our company certification, which is so important for official approval in Germany, will take place on September 8th.
As I have already published, the lamps have successfully passed the necessary tests, but it must also be proven that consistent manufacturing quality is guaranteed.
Here is a glimpse into my little workshop:
[Foto 3]
Coil winding machines (in the front) with generator warehouose (tubes in the corner of the room) and soldering/ testing desk
[Foto 4]
The effort involved in checking and documenting all production steps (receipt of goods, material and functional tests, various production steps through to shipping) has taken up a lot of time in the past few weeks and I have hardly been able to answer any questions.
I still need the remaining days to prepare for the audit appointment on September 8th and will then send out the survey on September 9th and start shipping all Wega lamps and the first Microlights at short notice (first the untreated and then the anodized parts). Otherwise I'm afraid of getting bogged down if things that are too important are running in parallel next week.
I hope for your understanding and will do my best to ensure that the certification and finally shipping of your lamps will run smoothly.
Cari sostenitori,
Negli ultimi giorni ho ricevuto molte richieste sulle spedizioni e un aggiornamento sullo stato attuale.
La situazione è la seguente:
    • Le luci Wega preordinate sono state prodotte e sono in attesa di essere spedite, mentre noi abbiamo già spedito le prime quantità rilevanti e imparato dagli errori.
    • È arrivato il primo piccolo lotto di pezzi in alluminio (ganasce dei freni) per i Microlight. Dopo molti campioni immaturi negli ultimi mesi, queste nuove parti stanno finalmente funzionando come previsto.
Contrariamente a quanto annunciato e a differenza dei campioni precedenti, queste parti non sono ancora anodizzate nere ma hanno ancora la superficie in alluminio nudo.
I nuovi campioni color argento (non ancora anodizzati) stanno finalmente funzionando ora.
Possiamo spedire queste parti finite in alluminio grezzo a clienti che non si preoccupano della finitura: la maggior parte delle parti anodizzate nere arriverà qui a settembre e quindi verrà spedita. La situazione del nostro fornitore è ancora difficile (ieri ho ricevuto cattive notizie riguardo alle nuove restrizioni Corona [tanto per non farsi mancare nulla] in questa regione), ma speriamo che ciò non influisca troppo sulla spedizione.
Prima consegna di campioni funzionanti per ganasce freno Vbrake/Cantilever (anteriore/sinistra) e bici da strada.
Con queste parti funzionanti, ora siamo pronti per inviare questionari (per aggiornamenti su indirizzo e premi) e spedire le luci preordinate.
Tuttavia non comincio oggi, [ma guarda...] ma voglio aspettare fino al 9 settembre (contrariamente ai miei annunci precedenti) perché la nostra certificazione aziendale, che è così importante per l'approvazione ufficiale in Germania, avrà luogo l'8 settembre.
Come ho già pubblicato, le lampade hanno superato con successo i test necessari, ma si deve anche dimostrare che è garantita una qualità di fabbricazione costante.
Ecco uno sguardo al mio piccolo laboratorio:
avvolgitori (nella parte anteriore) con magazzino del generatore (tubi nell'angolo della stanza) e banco di saldatura/collaudo
Lo sforzo di verifica e documentazione di tutte le fasi di produzione (ricezione merce, prove materiali e funzionali, varie fasi di produzione fino alla spedizione) ha richiesto molto tempo nelle ultime settimane e non sono riuscito a rispondere a nessuna domanda.
Ho ancora bisogno dei giorni rimanenti per prepararmi all'appuntamento di audit dell'8 settembre, quindi invierò il sondaggio il 9 settembre [vedremo] e inizierò a spedire tutte le lampade Wega e i primi Microlight con breve preavviso (prima le parti non trattate e poi le parti anodizzate). Altrimenti ho paura di impantanarmi se le cose che sono troppo importanti andranno in parallelo la prossima settimana.
Spero nella vostra comprensione e farò del mio meglio per garantire che la certificazione e infine la spedizione delle vostre lampade si svolgano senza intoppi.
Dirk di Magic Light
« Ultima modifica: Settembre 05, 2022, 12:09:37 pm by Vittorio »
  • Post: 3441
« Risposta #67 il: Novembre 10, 2022, 06:30:32 pm »
Miiii! Nonci pozzo creeedere!!
Aggiornamento 55 del 9 novembre 2022
Login data for confirmation database
Dirk Strothmann
9 novembre 2022
Dear Backers,
Yesterday I sent the first batch of login data (to German language backers) and today I will send the remaining data.  Worked well for the most part, but there were still questions at some points, so I made minor corrections before sending out the additional login data today.
We could not reach ~5% of the backers per mail and will collect these and send data "by hand" (by Kickstarter message) tomorrow.
The German newsletter (which I sent yesterday) for login is also available here (only viewable without personal login data):
https://www.kickstarter.com/projects/dynamodirk/magnic-microlights-bikelights-with-magic-non-conta/posts/3660210?ref=ksr_email_backer_project_update_unregistered_users
Among other things, there is sometimes good news, e.g. the traffic approval numbers (K-Nummer) for Germany after years of effort.
All backers should then have received their access data by Friday at the latest.
Cari sostenitori,
Ieri ho inviato il primo batch di dati di accesso (ai sostenitori di lingua tedesca) e oggi invierò i dati rimanenti. Ha funzionato bene per la maggior parte, ma in alcuni punti c'erano ancora domande, quindi ho apportato piccole correzioni prima di inviare i dati di accesso aggiuntivi oggi.
Non siamo riusciti a raggiungere il 5% circa dei sostenitori per posta e li raccoglieremo e invieremo i dati "a mano" (tramite messaggio Kickstarter) domani.
La newsletter tedesca (che ho inviato ieri) per il login è disponibile anche qui (visualizzabile solo senza dati di accesso personali):
https://www.magniclight.com/de/component/acym/archive/88-magnic-microlight-wega-zugangsdaten-zur-lieferbestaetigung
Tra le altre cose, a volte ci sono buone notizie, ad es. i numeri di approvazione del traffico (K-Nummer) per la Germania dopo anni di sforzi. Tutti i sostenitori dovrebbero quindi aver ricevuto i dati di accesso al più tardi entro venerdì. Grazie mille per il vostro sostegno! Dirk di Magic Light
Mo' vediamo....
EDIT: onore al merito, poco fa ho ricevuto la mail con istruzioni e credenziali per confermare/modificare il mio ordine; dopo cena provo a compilarlo. Peccato che le lucine non arriveranno in tempo per il November Porc...
RI-EDIT: modulo d'ordine compilato e confermato oggi, domenica 13; data stimata di consegna il 15 dicembre. Vedremo...
« Ultima modifica: Novembre 13, 2022, 08:52:28 pm by Vittorio »
« Risposta #68 il: Novembre 22, 2022, 10:47:02 am »
Dal canto mio ho iniziato a contattarli per un acquisto fuori dal circuito del crowdfounding, vedremo le tempistiche.
Stando al sito ufficiale dovrei spendere una quarantina di € in più per il set completo, ragionevole direi (specie perché, al tuo posto, probabilmente avrei rinunciato all'ordine).
  • Post: 3441
« Risposta #69 il: Novembre 22, 2022, 11:22:56 am »
Era la mia prima esperienza di crowdfunding e alla fine ho deciso che 89€ era una perdita che potevo sopportare, nel caso fosse andato tutto a ramengo. Però sarà difficile che mi prendano ancora... anche se 89€ investiti per 4 anni non mi avrebbero fruttato 40€, quindi dal punto di vista puramente finanziario ci dovrei aver guadagnato.
Ora vediamo quando arrivano e come vanno sulla Vitesse; per fortuna, mal che vada, posso sempre girarle sulla Espresso.
P.S. se vuoi aspettare la mia recensione per ordinarle, mi impegno a farla in fretta. Tra l'altro ho in programma di venire a Torino domenica 4 con la bici, ma escludo che per allora siano arrivate.
« Ultima modifica: Novembre 22, 2022, 11:24:35 am by Vittorio »
« Risposta #70 il: Novembre 23, 2022, 08:27:46 am »
Grazie per la disponibilità, sono curioso di vederle finalmente all'opera.
Non penso di muovermi in fretta neanche io, anche in considerazione del fatto che non so ancora come procedere all'acquisto (sempre che sia possibile).
Se la coda di ordini da evadere è lunga probabilmente ci vorrà un po'.
Probabilmente non sarò a tiro quella domenica, altrimenti ci si sarebbe potuti salutare di persona.
« Ultima modifica: Novembre 23, 2022, 08:29:56 am by Sbrindola »
  • Post: 3441
« Risposta #71 il: Novembre 23, 2022, 01:06:34 pm »
Ok, ci aggiorniamo
  • Post: 3441
« Risposta #72 il: Gennaio 26, 2023, 03:07:16 pm »
Avrei fatto meglio a non crederci...
Dopo che nella schermata di conferma dell'indirizzo era comparsa una data di consegna stimata del 15 dicembre; dopo che non era arrivato niente; dopo due mail rimaste senza risposta, oggi
Aggiornamento 58 del 26 gennaio 2022
https://www.kickstarter.com/projects/dynamodirk/magnic-microlights-bikelights-with-magic-non-conta/posts/3716531?ref=ksr_email_backer_project_update_unregistered_users
È arrivato il materiale per le Microlights
Cari sostenitori,
Con un po' di ritardo il nuovo materiale (definitivo) per le Microlight (e per i fari Wega) è arrivato qui per via aerea martedì. Con questo materiale ora possiamo assemblare le prime Microlight complete, inclusa la versione con numero K tedesco e le ultime ganasce dei freni in alluminio nero. Almeno gli ultimi problemi aperti potrebbero essere risolti con questi pezzi:
Nel frattempo sono state spedite quasi 1000 luci Wega e nelle prossime settimane ne seguiranno altre Microlight e Wega. Abbiamo ricevuto molte domande sulla consegna, gli aggiornamenti e le conferme nel nostro database e cerchiamo di elaborarle rapidamente e risolvere eventuali problemi. Anche se volevo evitare errori nella consegna, i sacchetti con questi 3 articoli sono rimasti nel magazzino di Shenzhen:
Ieri ho provato a procurarmi queste rondelle coniche qui, così come i bulloni Vbrake e i dadi a manicotto M5, ma senza successo. Sembra che dovrò aspettare la prossima consegna a febbraio per questi pezzi. Anche se si tratta di componenti dei freni "standard", potrebbe essere una cattiva idea spedirli senza di essi (le ganasce dei freni potrebbero avere le stesse parti, ma potrebbero anche differire leggermente e l'installazione non sarebbe possibile). Quindi prima assembliamo le luci qui e, si spera, riceveremo un piccolo pacco per via aerea entro 14 giorni.
La maggior parte del materiale può essere inviata tramite trasporto ferroviario solo dopo le vacanze del Capodanno cinese all'inizio di febbraio e arriverà qui circa 3 settimane dopo (e solo allora potrà essere assemblato e spedito). Avevo già annunciato questa spedizione ferroviaria per dicembre nell'ultimo aggiornamento e poi ho dovuto vedere come la data doveva essere posticipata sempre di più a causa dei massicci casi di coronavirus in Cina. Finora è arrivata qui solo la prima consegna per via aerea e aggiornerò di conseguenza i tempi di consegna successivi per le tue lampade nel nostro database nei prossimi giorni.
Grazie per il vostro sostegno ! Spero che ora i prossimi passi procedano senza intoppi.
Dirk
Io ormai non commento più...
  • Post: 1075
« Risposta #73 il: Gennaio 26, 2023, 08:32:35 pm »
Già! Meglio non commentare. Sarebbe troppo facile fare della sguaiata ironia. Leggendo il comunicato noto due cose.
Dal primo lancio a oggi sono passati cinque (5) anni. Chissa se quelli che hanno partecipato alla prima raccolta sono ancora tutti vivi.
Non ricordavo che facessero produrre i componenti in Cina. Vista la correttezza commerciale tipica dei cinesi, i tedeschi non temono di vedere cloni del loro prodotto in vendita su Alibaba a metà prezzo? Magari prima che escano le loro? Chi vivrà vedrà...
  • Post: 3441
« Risposta #74 il: Gennaio 26, 2023, 09:39:33 pm »
Beh, c'è stato uno che nel frattempo ha venduto la bici; io invece ne ho comprata un’altra…
Sul modo di lavorare dei cinesi, nel mondo del modellismo ferroviario si raccontano parecchi episodi più o meno coloriti, ma in genere si è trattato di “scorciatoie” prese per non perdere tempo a consultare il committente europeo (cosa che in effetti per il gioco dei fusi orari può voler dire anche due giorni di fermo); e così si sono visti fiumi di colla cianoacrilica su montaggi che avrebbero dovuto essere smontabili, corrimani montati al posto di tergicristalli eccetera….
Qui invece abbiamo tre sacchetti di pezzi dimenticati.
Paradossalmente l’unico caso di clone di cui io abbia sentito parlare sarebbe stato opera dell’editore francese Hachette, che avrebbe acquisito con scanner 3D il modello di una carrozza Rivarossi che poi è stata distribuita a prezzo stracciato in edicola.
Però il modellismo ferroviario è un settore con volumi e margini di guadagno risicati; magari i gadget tecnologici come le luci fantasma del buon Dirk sono più appetibili per i clonatori. O magari Dirk è stato più furbo e si è riservato qualche componente chiave; mi pare infatti che gli avvolgimenti dei generatori venissero prodotti in Germania.
