Knog Blinder Road 2 (luce anteriore)
Descrizione |
With the Knog Blinder Road 2, Knog introduces its first generation of Hi-powered bike lights specifically designed for road cycling. Delivering a colossal 200 lumen beam of light on the front, they're the first Blinder lights of their kind to give riders 100% visibility and freedom at night, all from a super-compact, super-light, USB rechargeable, waterproof, integrated silicone package.
Specifiche tecniche- 200 Lumens
- Light Dimensions: W53mm x H30mm x D63mm
- Weight: 75g
- Materials: UV-Resistant, industrial-grade Silicone Rubber Body and Straps. Polycarbonate Housing. PMMA Lens. Anodised Aluminium Heat sink. Anodised Aluminium Fascia and solid Stainless Steel MIMLatch
- Rechargeable Lithium Polymer (USB). This saves using about 600 AAA Alkaline batteries during the lights lifetime.
Features- Leds: 2 x CREE XB-D LEDs
- Lens: Use of an optic design to provide a balanced ratio of beam width and distance to safely illuminate you and the path ahead.
- Visibility: Visible from a distance of min. 1000 metres
- Beam Angle (degrees): Wide beam 22°- Hi/Low. Narrow beam 15° - Hi/Low. Dual beam 15 and 22°combined - Hi/Low.
- LiPo Technology with battery protection circuit. USB Rechargeable and extension cord included.
- Constant current drive technology: Maintains consistent brightness throughout specified run-time.
- Integrated USB Plug: Designed to be exposed to the elements, the plug is also waterproof and will not be damaged by exposure.
- Waterproof: 100% Waterproof and Dust Proof.
- Light Modes: Total of 8 light modes: 1. Narrow Low Beam, 2. Narrow High Beam, 3. Wide Low Beam,4. Wide High Beam, 5. Dual Low Beam, 6. Dual High Beam, 7. Flashing Alternate, 8. Flashing-1 LED Steady/1 LED flashing.
- Burn time: Low-beam modes: Steady 2hr, Flash mode 6hr. High-beam modes:Steady 1hr / Flash mode: 4hr.
- Charge time: 5 hour charge time
- Button: New longer button push on (0.75sec) prevents accidental activation of your light. Short presses switch modes continuously. Similarly, the light is switched off with a long button push off (0.5sec).
- Low battery indicator
- Thermal management: Automatically regulates the light output for optimum performance when the bike is stationary and in motion.
- Bike Attachment: Two removable silicone straps for bars 22-28mm / 29-35mm. Helmet mount included
- Testing: The Blinder Road has been tested against the following; Drop tests, corrosion tests, UV tests,Electrical shock and static, vibration and impact, temperature and humidity, cycle testing and CE certification.
Prezzo | 69€ EURFonte |
http://www.knog.com.au/gear-hi-power-lights/blinder-road-front.phpsKnog Blinder Road R (luce posteriore)
Descrizione | With the Knog Blinder Road R, Knog introduces its first generation of Hi-powered bike lights specifically designed for road cycling. Delivering a colossal 70 lumen strobe on the rear, they're the first Blinder lights of their kind to give riders 100% visibility and freedom at night, all from a super-compact, super-light, USB rechargeable, waterproof, integrated silicone package.
Specifiche tecniche - 70 lumens in strobe mode (peak)
- Dimensions: W27mm x H76mm x D52mm
- Weight: 52g
- Materials: UV-Resistant, industrial-grade Silicone Rubber Body and Straps. Polycarbonate Housing. PMMA Lens. Anodised Aluminium Heat sink. Anodised Aluminium Fascia and solid Stainless Steel MIMLatch.
Features- LEDs: 1 x CREE XPD XB-D LED, 3 x Super bright LEDs
- Lens: Collimated optics.
- Visibility: Visible from a distance of min. 1000 metres. Incorporates side Illumination with visibility of 290°
Beam Angle (degrees): Wide beam 80°. Narrow beam 22°
- Light Modes: 5 light modes: 1.Steady, 2.Fast, 3.Chaser, 4.Peleton, 5. Eco-Flash.
- Burn time: lasting up to 3.5 hours in Steady mode, 4 hours in Fast, 5 hours in Chaser, 13 hours in Peloton Mode and 20 hours in Eco-Flash.
- Button: New longer button push on (0.75sec) prevents accidental activation of your light. Shortpresses switch modes continuously. Similarly, the light is switched off with a long button push off (0.5sec).
- Bike Attachment: Tool-less attachment for rear posts measuring 22-32mm
Prezzo |
49.9€ EURFonte |
http://www.knog.com.au/gear-hi-power-lights/blinder-road-rear.phpsVendibili assieme con il Twin Pack al prezzo di
114€ EURFonte |
http://www.knog.com.au/gear-hi-power-lights/blinder-road-twin-pack.phpsPensavo erano già state inserite ma non ho trovato nulla a riguardo, beh non c'è che dire, sia 200 lumens per l'anteriore che 70 lumens per la posteriore in relazione alla compattezza trovo siano molto buone, il prezzo è un tantino alto..ma d'altronde..
